Notices
How to fit 305/75 r16 tires
Old May 13th, 2014, 6:14 PM
jmm3h7's Avatar
Default How to fit 305/75 r16 tires
I have a 98 k1500 z71 chevy and I am wanting to run a 305/75 r16 tire. I would like to use a 16x10 rim and could only find in a -25 offset or more. How much of a lift would I need to fit these tires and is there a way to lift it other than just a suspension lift because I don't want to spend $1000 if I don't have too. Thanks for all of the help.
Old May 13th, 2014, 11:22 PM
country_09's Avatar
You could turn up the stock torsion keys and run a 3" body lift to fit them. That should do the trick
Old May 14th, 2014, 1:42 PM
jmm3h7's Avatar
I thought about that but I don't like how you can see that much of the frame. I can afford a 3 inch lift but I think that I will need a little more room to fit those tires. How hard would it be to make a homemade one inch body lift or does anybody where to find one?
Old May 14th, 2014, 10:41 PM
country_09's Avatar
You could buy 1.5" body pucks, or 2" and then make some custom brackets for it. Or find a used suspension lift
Old May 17th, 2014, 11:30 AM
jmm3h7's Avatar
Would a 305 fit on a 9 inch wide rim? if so then I could get a wheel with less offset and it would probably solve all of my problems
Old May 17th, 2014, 12:26 PM
country_09's Avatar
Should be fine with a 9" wide wheel on that tire with some crank on the torsion keys. You could probably do the 10" wide wheel as well, but it's been a while since I messed with a 98 or older truck
Old May 17th, 2014, 2:55 PM
jmm3h7's Avatar
the only reason I asked about a 9 inch wide rim is because I can get it with only a -12 offset. I decided to just do it right and buy the 4 inch rough country suspension lift. Do you know a ten inch wide would fit without trimming with it being a -24 offset? because I would prefer a 10 inch wide rim but I don't want to have to trim anything if that is possible
Old May 17th, 2014, 9:28 PM
country_09's Avatar
Should be fine with a 4" lift on te x10
Old May 18th, 2014, 8:23 PM
jmm3h7's Avatar
Do you mean an 18x10?
Old May 19th, 2014, 11:30 AM
country_09's Avatar
X10 just means width of the wheel. It can be any size, 20x10, 18x10 16x10 etc. just a 10" wide wheel lol
Quick Reply: How to fit 305/75 r16 tires
