How rare is a 1998 Z71 crew cab?
#11
Ok, more info. I found out that the truck was converted to a crew cab by Centurion Conversions. I forgot to get any pics for you guys but I'll get some when I go back to look at it again.
It does have a few problems, biggest is a crack in the frame. It looks like the truck was put on a lift improperly and the bottom of the frame rail was bent up causing it to crack under the drivers side door hinge area. It is not a hard fix since the vertical section is not buckled at all and everything is still straight but still an issue. It also needs a front axle seal and the power steering pump is going out.
I'm gonna go work on a deal tomorrow or Monday and see what they are willing to do.
#13
I've seen a few 4-door 1500s, 1 was a 93, the rest were a lil newer. The 93 originally came from Canada. The other day here on base, I saw my first Chevy 3500 Crew Cab Short Bed dually. It was a 95 or 96, had Alaska plates.
#16
Classifieds Moderator
TruckForums Liaison
TruckForums Liaison
So I was pulling out of the gas station yesterday and I saw a red 96-98 Crew Cab 1500 Z71. It was sexy.
I love your truck Hotsandrail, A backseat would come in handy every now and then.
And good luck cb11 with your purchase!
#17
I knew you guys would come through with some good info. I picked up the truck yesterday but in case you haven't watched the weather there is over a foot of snow here in VA. I left it at the hospital after picking up my wife and drove her home in her ride. I'll post pics when I get it home, but it looks exactly like the one above.
#18
They fixed it today. Said he put something back together wrong after fixing the axle seal leak. We've still got some snow on our side road so I got to test it out a little and it did just fine. It's finally home so pics will be coming tomorrow some time.
