Last edit by: IB Advertising
See related guides and technical advice from our community experts
- Chevrolet Silverado GMT900 How to Replace Brake Master Cylinder
Step by step instructions for do-it-yourself repairs.
I think its my Brake Master Cylinder
first of my break pedal goes right to the floor.
When i step on my breaks, i hear something like air
I think its my master cylinder,
and other ideas?
thanks guys
97 chevy c/k 1500
and other ideas?
thanks guys
97 chevy c/k 1500
RE: I think its my Brake Master Cylinder
Might be a stupid suggestion but ive had something similar happen in my old cavalier, broken brake line, no fluid so its basically pressureless. Check your brake fluid to vito this possibility
No broken break lines, i checked when i did my breaks..NO LEAKS
fluid looks good just black.
no i dont know if its the brake booster or Master cylinder, any way to pin point that out
brake pedal goes down to the floor + hissing noise= leaking booster diaphragm. diaphragm can be serviced seperately or replace booster.
otherwise, brake fluid level will be lower than it's supposed to be and you'll have obvious signs of brake fluid leaks somewhere.
ok, here it is from a book:
1. depress the pedal and start the engine. if the pedal goes down slightly, operation is normal
2. depress the brake pedal several times with the engine running and make sure that there is no change in the pedal reserve distance
airtightness check
1. start the engine and turn it off after one or two minutes. depress the brake pedal several times slowly. if the pedal goes down farther the first time but gradually rises after the second or third depression, the booster is airtight.
2. depress the brake pedal while the engine is running, then stop the engine with pedal depressed. if there is no change in the pedal reserve travel after holding the pedal for 30 seconds, the booster is airtight.
i am not the one who wrote the instructions.
airtightness check
qzack1
August 28th, 2011 12:50 PM
randys94
May 14th, 2009 9:39 PM
