Idle Issues, PLEASE HELP!!
Old Apr 23, 2012 | 5:29 PM
astephens's Avatar
Default Idle Issues, PLEASE HELP!!
I have a 1989 Chevy 1500, V8, 5.0, Automatic, about 160,000 miles.
It idles really rough at the start and sometimes will not stay running. I have to give her gas to keep her going. Once I get it started, the idles stay rough, from high to super low, for about 3-5 minutes. Once it settles the idle stays pretty low. A couple of days here and there it idles REALLY high. It goes through these 2 stages every so often but for the most part just the low idle and rough start. I have heard it could be many things from fuel pump to sensors. Just looking for some additional help from guys that know their stuff
Old Apr 23, 2012 | 6:04 PM
camotruck55's Avatar
I'm not an expert, but I had the same problem in a '93 S10 Blazer. It was the electronic EGR valve. Swapped it out with a new one and it was fixed. Although I think my check engine light was coming on with this problem. Just a thought.
Old Apr 23, 2012 | 6:14 PM
astephens's Avatar
Thanks! Any info is good info! The check engine light is coming on. I left that part out. The light flashes according to the idle. When it gets low the light comes on. Then sometimes it comes on and just stays on.
Old Apr 23, 2012 | 7:54 PM
A dirty MAF can cause some nasty idling. Try reading the code when the check engine light is on. That would help narrow it down.
vet67coupe
May 10, 2014 11:33 PM
beezey
Nov 24, 2011 4:01 PM
