Notices
idling problems tried everything
Old August 1st, 2011, 4:04 PM
  #11
kevinkpk's Avatar
Originally Posted by eirrek
i changed regulator already but i will disconnect and make there is no gas just incase i got a deffective part
Reply back either way please.
Old August 2nd, 2011, 8:00 PM
  #12
eirrek's Avatar
ok i rechecked the fuel regulator and no leakage, took apart throttle again and cleaned as far back as i could get my hand egr pipe in the way a little, plus did the sea foam through the booster. think maybe an intake leak? not loosing any fluids and i sprayed everywhere double checking, anyway a ac compressor could be pulling to much even with it off?
Old August 2nd, 2011, 8:30 PM
  #13
kevinkpk's Avatar
Does it idle/run ok without a/c? If not, could be a vacuum leak, with that what has changed?
Old August 2nd, 2011, 9:02 PM
  #14
RacerX's Avatar
intake leak at manifold to block?
Old August 2nd, 2011, 9:18 PM
  #15
Professional Mechanic
MDTAHOE's Avatar
Replace the intake gasket, very common problem. By process of elimination there is nothing left.
Old August 2nd, 2011, 11:50 PM
  #16
kwmerkel's Avatar
Your Computer may need to be reset at the dealer, i would imagine this would fix the problem. Since you added all the new parts this is not uncommon to have to do.
Old June 11th, 2012, 8:51 PM
  #17
eirrek's Avatar
Talking idling prob fixed
thank you for all the help. It was the intake that was leaking. I guess it is a big problem with the plastic intakes the bolts get loose or the intakes themselves worp. I changed the gasket, problem solved. thanks
Old June 11th, 2012, 10:02 PM
  #18
MDTAHOE's Avatar
Thanks for the update. It is always great when people let us know.
Old January 5th, 2013, 1:25 PM
  #19
New User
Awaiting E-mail Confirmation
bigotha2's Avatar
was it an easy job to tackle i got to do the same to my tahoe .
dartlord2001
1988 - 1998 (GMT400)
89
January 1st, 2024 5:30 PM
trippymg
November 17th, 2016 8:00 PM
Goblin1488
March 21st, 2013 7:52 PM
VanMan12
August 17th, 2012 5:54 PM
toddandtamara
December 25th, 2008 7:07 PM
Quick Reply: idling problems tried everything
