Last edit by: IB Advertising
Browse all: Interior Guides
- Chevrolet Silverado GMT800, GMT900, and K2XX How to Disarm Ant-Theft Lock
Ignition Cylinder Lock
I have a 96 1500 pickup. The ign. lock on the column is sticking and sometimes will not work properly as the kes are VERY worn...Having said that, is this a dealer only item or can I source a new lock and keys aftermarket. And will it need to be coded to the trucks ECM?
Regards
Regards
I recently had that problem but with a 85 impala. I had to get a 20$ aftermarket key and cylinder, but since your truck is 10 years newer I don't have the answer to the ECM question. On my car the steering wheel and all of the internals had to come out.(tilt wheel and turn signal switches) I had trouble getting the push plate and circle clip off of the steering column so I rented a puller type tool from autozone. The steering wheel column panels had to move to get all of the switches out of the way but after that it's right there.
Keep in mind this was on a 85 so things are probably a little different.
Regards
Regards
The truck does not have passlock. All the door locks are worn as well and it is my intention to replace all the lock cyls. I think I should replace the ign. lock cyl and not just the key as I can remove the key after the truck has been started.
Regards
Regards
I just bought a new lock cylinder from Advance Auto Parts made for my truck year and was able to install it myself. I have a service manual that told me step by step how and youtube has a lot of great videos. BUT my truck has no anti theft and is not a coded key so it was a simple remove/ replace job.
Guess I'm hard headed...I went with the OEM part. I only use aftermarket when I can't get OEM stuff. Costs more but the parts always fit and work correctly.
97chevypickup
September 9th, 2012 6:04 PM
cavalierguy
February 24th, 2010 7:56 AM
