im at a loss
im at a loss
i have a 95 k 1500 z71 i have replaced o2 sensor three times, map, egr valve,purge valve, temp sensor on the side of the block and injectors full tune up fuel filter and ecm and still have a code 13 and its running very rich all the wire seem to be in tact inside th wire loom ....code 13 is a open circut or low activity with o2 sensor ....please any suggestions would be absolutely awsome thanks in asvanced!
What I read code 13 is left bank O2 sensor open, or no input. I don't know what the resistance is supposed to be, but open circuit is just that. Replace the part, or at least inspect the wire connector.
