Last edit by: IB Advertising
- Chevrolet Silverado GMT800, GMT900, and K2XX Why is Instrument Cluster Broken
Guide to diagnose trouble and recommended solutions.
instrument cluster problem
#22
I have the battery light stay on in the message board, odometer not working, gas gauge not working, temp. gauge not working, heater/ac blower not working. Replaced the ignition switch, new battery, new altenator, replaced cluster, replaced pcm. Checked and cleaned all grounds. Nothing solved the problem. It turned out to be the mega fuse under the hood for the ignition B.
Thank you so much I literally tore my truck up side down I replaced ignition switch wiper switch heater control module and to find out it was just a mega fuse
#23
i have a post about this as well, but my dash the gear indicator hasnt worked at all. and a few other items dont work as well, such as the left turn blinker doesnt work but it does blink outside. then there the main problem i am having. so far the speedometer will stop working and go below the 0mph mark and it will effect the tach as well. and so far i seen the gear indicator work but that when the tach and speedo stop working all together.
but so far the speedo not working has happen 5 times so far and the tach 3 times. and from what i have read and been told that the dash cluster is only covered for a few yrs. so if your like me and its 11 yrs old your SOL cause GM doesnt care if it just happens now..
anyways i have a ton of electrical problems with this truck since i got it in 2013 and i wish i would have kept my old truck now.. ill never buy a cheap built chevy ever again...
#24
Hello!
Have a 2004 Chevy Silvarado, duramax diesel...it's my husbands.![Smile](https://chevroletforum.com/forum/images/smilies/smile.gif)
He's deployed and its here with me.
Since he bought it we've replaced the instrument cluster, it wasn't working when purchased. new cluster worked for a bit and then quit. He's replaced the motors and lights, switch on transmission(?) Pretty much everything you all have recommended.
So, now I'm driving this truck occasionally. I have no idea how much gas is in it have to use gps to check speed and count to shift to drive, reverse etc.
My mechanic said replace the cluster because he plugged his into my husbands truck and everything worked.
So my question to you guys is how to I make sure I buy the correct part?
I found one on eBay identical to the current one. says its interchangeable. I'd like to surprise my husband when he gets back, so any help is appreciated!
Mechanic is busy bro in law, so I'm kinda on my own as far as getting the part.
Thanks!
Thanks!
#25
What a nice gesture for your hubby! Do you have a single sister? LOL!
These trucks are prone to instrument panel troubles. I have a 2004 (gasser) and the speedo, odometer, water temp & fuel gauges work perfectly. The tachometer, oil pressure and voltage gauges kind of have minds of their own.
I figure that I will live with it - unless the speedo, odo or fuel gauge give me problems.
Good luck!!
#26
I have a 2001 Chevy 1500 Silverado Z71 4x4 Shortbed that has the same symptoms that are described for the 2003 models and above. Will the repair the 6x GM GMC Stepper Motor X27.168 Speedometer Cluster Repair Kits work in my 2001?
Thanks
Thanks
Hey guys, sounds like there's several problem being brought up here, I'll try to help best I can.
On the 99-02 trucks the odometer/PRND123 display will go out intermittently and come back on if you hit a bump or bang on it with your hand - this is caused by a poor solder connection where the plug is soldered to the circuit board and it can be repaired. See here for a guide on how to do it - Silverado odometer problems
The fuel gauge problem on that generation of truck us normally caused by a bad fuel sending unit on the fuel pump assembly in the tank, requires replacement.
On the 03-06 trucks the gauge problems are typically caused by bad gauge motors which can also be fixed, here's some info on how to fix them yourself - Silverado instrument cluster problems
That generation of truck also has fuel sending unit failure a lot which will cause the fuel gauge to read wrong, requires replacement.
The 03-06 trucks have another issue where the entire instrument cluster will quit all at once and sometimes come back on/off/on, chimes ringing, lights flashing,etc. This can be caused by a faulty ignition switch, requires switch replacement.
And finally, on the 03-06 trucks if you notice the 4 gauges on the right quit suddenly all at once along with lights coming/staying on it's a failing IC chip on the circuit board - cluster replacement required.
Hope that sheds some light and can help some of ya.
Fred
www.DrSpeedometer.com
Oh ya, one more I see a lot - if your oil pressure gauge is bouncing from 0psi to 80psi don't panic, it's not your motor or your gauge whacking out. It's a poor electrical connection around the oil pressure sensor/switch causing it to read full pressure then 0 pressure.
Fred
#27
Hello!
Thanks!
Thanks!
We look forward to helping you out on this and can answer any questions that you might have.
Thanks,
#28
I have an 01 Silverado 1500, 5.3 Auto. About a year ago, I hit a HUGE pothole and the gauges all went crazy. Every time I hit a bump they went crazy. If I was sitting still, they were fine. Then all of a sudden one day they went crazy and never came on again. I have replaced the Instrument cluster, keylock cylinder and the ignition switch. I am about the give up. Help!
#29
I'm kind of interested in any feedback on this topic. My instrument cluster started having intermittent problems, then finally quit working all together. In trying to track down the problem, I noticed that I had a poor battery ground and tightening the connection seemed to make a difference.
Out of curiosity, does your panel go through the normal key-on sequence with indications for things like air bags and emergency brake and so on? Mine used to do that, but doesn't any more. I'm not sure what that means, but I'm reasonably sure it's not a good sign.
Thanks!
Thanks!
#30
I know this an old forum but I had the same problem with my 03 Silverado and my issue was the harness that plugs into the cluster was worn at the pin inserts the wires just wiggles around in there replaced that and BAM got my gauges back up and running no issues since !! Hope this helps man
tim8722 (December 19th, 2022)
