Notices
intermitten low idle misfiring under load
Old December 12th, 2012, 9:05 PM
  #11
kevinkpk's Avatar
Originally Posted by prowe3
I do not have a OBDII scan tool, so I do not know what what the coolant temp sensor is reading. are the computer and dash gauge on separate sensors?
Don't think so. What MD is asking about the color of the spark, if it isn't blue or white. Unless you have a check engine light you won't have a code. No code likley it is a mechanical problem. Pull a couple of spark plugs, post back what they look like.
Old December 17th, 2012, 4:48 PM
  #12
prowe3's Avatar
OK so I hooked the fuel gauge up while I was at work and when I came out 8hrs later the fuel pressure had dropped to 20 psi, but it still fired back up to take me home. So I let it sit all weekend and my driveway has a slant leaning toward the street. Come Monday morning it wound not fire back up. So my question is the fuel check valve in take sending unit or is it part of the fuel pump?
dslemaire
August 23rd, 2018 9:46 PM
jaysranger
May 9th, 2015 3:10 PM
gray2000
June 5th, 2014 7:26 AM
86silver
March 9th, 2012 5:57 PM
rteas48183
March 18th, 2008 4:59 PM
Quick Reply: intermitten low idle misfiring under load
