Intermittently not starting
Old Sep 4, 2006 | 3:23 PM
cmmaloy's Avatar
Default Intermittently not starting
Sorry if this has been covered, I searched but couldn’t find anything close.
I have a ’05 4.3l. Occasionally I’ll turn the key and get nothing no click no crank, nothing. Kind of like it’s in Drive and I’m trying to start it, but its not. When this happens I usually slide the shifter through all the gears and adjust the tilt steering (I’m assuming that the problem is associated with the switching mechanism that tells the ignition that it’s in park or neutral). I’m not sure if this is doing anything or not, but after a few attempts it finally turns over as it should. I brought the truck to the dealer but couldn’t replicate. Has anyone experienced something similar?
Thanks
Old Sep 4, 2006 | 9:52 PM
Nomad76lj's Avatar
Default RE: Intermittently not starting
the two things i would try would be to see if the battery is conected properly and also when it wont start try putting the truck in nutrel and see if it starts. this would be a start at least. also what kind of battery is in it? if its an acdelco iv heard a few bad things about them going bad insde the case so it may look good on the outside and be broke inside so if thats the case you may want to change the battery as well. hope all this helps a bit.
Old Sep 5, 2006 | 1:35 AM
bradstump's Avatar
It could possibly be a bad starter relay. next time it does it, turn your headlights on, and have someone watch them while you try to start. if they dim, it's likely in the starter. If not, probably in the relay circuit. there still could be many different things. these are just possibilities.
Old Sep 5, 2006 | 5:07 PM
Darrell's Avatar
I had the same problem on a 1995 Chevy pickup. Plenty of power for the horn, lights, etc... But nothing when I turned the key to the start position. It turned out to be the connection at the battery. Clean the battery cable end and make sure you have a solid connection.
goyakpacking
Jun 29, 2015 4:54 PM
MikeA
Aug 23, 2011 8:20 PM
jcastle
Sep 28, 2009 7:38 PM
jen10001
Chevelle & El Camino
May 15, 2008 5:54 PM
jwboudreau
Apr 25, 2008 6:48 AM
