Lemon....
Old Jan 26, 2010 | 9:11 PM
RockyS.'s Avatar
Default Lemon....
I hope I didn't buy a lemon. Have been coming across minor issues with my 05 silverado 4x4. In the process of trying to fix a few or at least try. Thanks to you guys who have been helping me with my water issue.
Here's 2 things that have come up. The front running light blinks when I use the turn signal but when I turn the lights on the light goes out and yet it still blinks when I use the turn signal. ??????
Next.... I had dome light problem that I fixed (left door wiring wasn't plugged in all the way on fuse panel) which has caused this.... Occasionally the light does not come on when I open the door, sometimes when I turn the truck off and open the door the radio continues to play which is not right. When these things occur I open and close the door which helps or jiggle the fuse box panel. ???? Any how sorry for being long winded just hoping I didn't buy a lemon.
Rocky
Old Jan 26, 2010 | 9:28 PM
MDTAHOE's Avatar
Professional Mechanic
Sounds like you have a bad ground at the light usually it is lost at the socket. Also sounds like you need a new door pin switch.
Old Jan 26, 2010 | 9:35 PM
RockyS.'s Avatar
Haven't tried this yet but.... Was going to take bulb from the other side and see what happens. Wasn't sure if it would fix the problem but thought I would give it a try. Is the door pin hard to replace?
SWRidin
Apr 23, 2011 10:06 PM
rugrat1965
Feb 5, 2009 10:01 AM
mrlant
Nov 11, 2007 7:16 PM
Pogi
Uplander
Aug 17, 2006 1:18 AM
