Limited Sponsorship for 2024 Silverado trucks - Custom-Fit LEDs Solutions!
Platinum Sponsor
Location: 9155 Archibald Ave Ste. C, Rancho Cucamonga, CA 91730
Calling Silverado owners! 🚨
Is your 2024 Silverado equipped with halogen headlights? Looking to upgrade to the LED headlights found in other 2024 trims? No need to envy any longer—Lasfit has got you covered!
Lasfit's custom LED headlights bulb for the 2024 Silverado are favored for their powerful light output and dual cooling system! These custom Pro series LED bulbs offer exceptional performance and we can't wait for you to experience the difference they make on your 2024 Silverado.
👉5 Participants Only.
👉20%~100% OFF to get LED headlight bulb.
👉Looking for
2022-2024 Silverado 1500
2020-2024 Silverado 2500/3500
👉US address only
Welcome to contact us by email in the format below:
1. contact email: forum.lasfit@gmail.com
2. Title: Your forum user name - Pro-CS-01L LEDs Testing
3. The email content includes:
* The year and trim of your Silverado.
* What are your current headlight? OEM halogens or aftermarket LED bulbs?
* What are your expectations from these new LED lights?
Some Outstanding Features:
💡 Introducing the custom LED bulbs from Lasfit, specially designed for Silverado headlight. With their carefully designed structure, powerful performance, and reliable heat dissipation, these bulbs will take your Silverado's lighting game to a whole new level!
✅ High Brightness with Optimal Beam Pattern: Pro-CS 01L LED bulbs have a true power of 50W and 5000 lumens per bulb, with high brightness, providing clear vision for safe driving. Besides, it features 80*80MIL high lumen LED chips and an accurate mount socket design, ensuring the optimized beam pattern with a clear cut-off. Safe and powerful!
✅OEM-design extended Dust Cover: Custom dust cover, not only can protect the LED bulbs from water/dust/moisture/other messes, but the extension design also provides a bigger for the best heat-dissipation effect. With the combination of two fans, it forms a dual cooling system, ensuring strong heat dissipation and prolonged LED operational status and lifespan!
✅ Easy Installation: Installing these upgraded LEDs in your Silverado is a breeze. Simply plug and play, and you'll be amazed at the instant transformation they bring to your truck's lighting system.
⭐ Don't Just Take Our Word For It ⭐
👉Looking for
👉US address only
LASFIT
2019+ Silverado (GMT-T1)
August 24th, 2023 8:55 PM
Christcorp
2007 - 2013 (GMT900)
February 26th, 2023 4:50 PM
