Notices
low oil pressure on rebuild..
Old July 13th, 2009, 10:16 AM
rog777's Avatar
Default low oil pressure on rebuild..
just rebuilt 99 silverado 6.0L.. message canter is reading low oil pressure... when removing the motor the oil sending unit was cracked.. I am not sure if that is why I am getting the reading..Pulled off the valve cover then started the motor.. There was a small stream of oil coming out of the push rods at idle.. Never seen a 6.0l before but I am use to the oil shooting all over the place.. Is this normal? I did replace the oil pump during rebuild.. The only code coming up is the 02 sensor..
Thanks
Old July 13th, 2009, 11:24 AM
Professional Mechanic
MDTAHOE's Avatar
You really need to put a mechanical oil pressure tester on so you can see the actual oil pressure, before any damage is done.
usernamehere
August 2nd, 2021 12:07 PM
Eric Sherden
September 24th, 2013 1:21 PM
not_a_car_dude
September 15th, 2013 7:41 PM
MikeShirk
December 31st, 2012 10:39 AM
larry_chip
April 24th, 2007 11:46 AM
Quick Reply: low oil pressure on rebuild..
