my drivers side door has started rubbing front fender
Old Mar 10, 2012 | 5:50 AM
rifsm1's Avatar
Default my drivers side door has started rubbing front fender
I have a 2007 Zlt Silverado and when i open the front drivers side door its started rubbing the fender and scraping the paint it has the swing out half doors in the rear extended cab part, has anyone else had this trouble? if so how do i fix it?
Old Mar 24, 2012 | 11:43 PM
Patricia Garner's Avatar
can you pull fender up ?? few bolts under hood and few in wheel well only needs a 1/4 inch
Old Mar 25, 2012 | 9:12 AM
96 Junk That Moves's Avatar
Probably worn hinge pins...grab the door at the bottom and see if it moves up when you pick up on it.If so the hinge pins are worn out and the door has dropped a bit.
Easy fix. Just replace the hinge pins. Nappa sells pin kits.
Old Mar 26, 2012 | 12:37 AM
Doug Roberts's Avatar
Don't think its pin it the washers I forgot the name but yeah Napa will have a kit or just washers if not move fender like I said
ericconn
Jun 19, 2012 9:56 AM
bpeter3429
Jul 22, 2010 9:02 PM
ChevroletR
Apr 6, 2008 11:24 PM
Propilot23k
Feb 28, 2008 5:45 AM
