Need Help blower problem
Old May 28, 2010 | 10:43 AM
atc31510's Avatar
Default Need Help blower problem
I have a 04 silverado and have replaced both the resistor and the blower motor. The problem is when i turn it to speed 5 I will start smelling wires burning. works fine 1-4 will only do it on 5. I traced the smell back to the resistor and it is getting real hot and starts to burn up. Any help would be great.
Old May 28, 2010 | 11:02 AM
maxxman04's Avatar
sounds like bad ground, maybe main power wire and/or connectors bad, wrong resistor, or the actual switch is bad.
Old May 28, 2010 | 1:46 PM
Dee74's Avatar
Check this site out. I just ordered the parts for mine today.
http://www.sparkys-answers.com/2008/...ower-inop.html
Old May 29, 2010 | 1:50 PM
Dee74's Avatar
OK I recieved my parts in less than a day and installed them and we are all set. You have to change the wire harness and the resistor att he same time. The exact link is
http://store.the-electric-connection...unt2=579688668
All I needed was some wire cutters, wire strippers, electrical tape, and a lighter to melt the shrink tubing. Everything else was supplied. I save $170 from what the dealer wanted. The resistor was AC Delco and the wire harness was delphi. I would definitely order from these guys again
go44
11
Mar 3, 2020 4:18 PM
HotRodRick
Chevelle & El Camino
Mar 22, 2015 2:09 AM
'04 impala
Jun 24, 2014 7:57 AM
spartanzz
Aug 6, 2012 3:42 PM
rmorton
Feb 9, 2010 12:48 PM
