Need help with climate control blower!!! Crucial!!!
I have a 2005 Silverado that is having issues with the heat/ac blower? the heat and ac work perfectly on 1-4 but when I switch to 5 it stops blowing entirely?! I replaced the resistor and also replaced the climate control switch?!Could it be a fuse? I checked the 10a fuse under the hood and it was fine?! What else could be wrong that's causing this issue? Thank you in advance to anyone that helps out!!
