Need help with emissions problem on a 1987 silverado 5.7 tbi
Old Feb 9, 2010 | 1:16 PM
Heinousacts's Avatar
Default Need help with emissions problem on a 1987 silverado 5.7 tbi
Hello my truck recently failed the low speed test on both co and hc.
I have replaced the cap,rotor,plugs,wires,and air filter and it is still failing.
Any ideas where to go next?
Old Feb 9, 2010 | 1:24 PM
mudmaniac's Avatar
Ride of the Month
May 2009
Try advancing the timing a few degrees and have it re tested.
Old Feb 9, 2010 | 1:26 PM
maxxman04's Avatar
oxygen sensor, catalytic converter, muffler. check for exhaust leaks, vacuum leaks. maybe even replace gas cap if that hasn't been done for awhile.
Old Feb 9, 2010 | 1:44 PM
The timing is advanced 2 degrees, and the guy at the emissions said it would be failing a different test if it was the cats or exhaust. I checked the three vacuume lines at the throttle body and they seem fine.
I did notice today the there are only 2 lines plugged into the canister, does anyone know where to find a diagram that shows where all the lines from the charcoal canister should run to?
desert_chris
11
Jul 14, 2025 8:39 PM
krazyswede
Apr 9, 2009 12:09 PM
smallblocks
Mar 14, 2008 12:10 AM
smallblocks
Mar 13, 2008 10:11 AM
Hegemone
Dec 10, 2007 10:15 AM
