Need Help with Horn on 2007 Silverado
I just 'inherited' a 2007 Chevy 1500 Z71 4x4 crew cab that came with a few issues. One that I am having a hell of a time with is with the horn. It will not sound from either the steering wheel, or from any other type of action (key fob clicks, etc). Every once in a while, it will let loose just the littlest squeak, but thats it. I have already changed the horn fuse, and bought a new relay, but I cannot find where the actual horn relay is located... Does anyone have clue where I need to look, or what other possible cause may be creating this issue?
Thanks in advance!
Thanks in advance!
So I guess the way the horns are set up is that if one goes out, the other does not work either? As I assume they both run off of the same electrical circuit? How difficult was it to replace them in your suburban? Where did you get the replacement horns?
Autozone. $20 for 2. High and low tone. They dont normally go out at the same time, but it happens.
Yep, the horn receives the power and usually grounds to the radiator support and there is a extension that connects it to the 2nd horn in series.
Official GM Rep
Gaigebacca,
It depends if it is a classic or new style Silverado. Both were made in 2007. If it is a classic Silverado there is a replaceable relay in the under hood fuse block. If it is a new style Silverado the horn relay is part of the printed circuit board that is only available with UBEC (under hood bussed electrical center).
Thank you,
Elizabeth, Chevrolet Customer Service
Thank you,
CruiserC-5
May 26th, 2015 12:23 PM
1978 Chevrolet C10 half ton horn contact/ horn wiringI have a 1978 Chevrolet C10 that it's horn does
isaac_22
December 26th, 2007 9:23 PM
zulu
March 28th, 2007 4:58 AM
