New to Diesels - What to expect with maintenance?
Any tips on diesel maintenance? I'm trying to determine how different it is to maintain a diesel vs. gasser and get an idea for the maintenance costs.
I'm looking at purchasing a 2007 Silverado 2500 HD diesel with low miles. It's needed totow a large travel trailer. However,normal use will be driving to and from a train station (10 minutes each way) with weekend trips to church (35 minutes / 24 miles) and occassional trips to the store. Not a lot of long driving times.
Thanks, Dave
Thanks, Dave
RE: New to Diesels - What to expect with maintenance?
Buy the truck, and buy a 4 banger. You don't want to make short trips with a desiel. Much less a turbo Desiel. It's not good for them.
Maint will be the same as for a gas engine. I don't know how long glow plugs are supposed to last. Air filters, fuel filter/fuel water separator on desiel. (drain water at least once a week)
The fuel water separator and glow plugs are the only thing I can think of off the top of my head that are really different.
Make sure you use desiel engine oil.
well there is a big difference in maint.. not really alot your just buying stuff in bigger quantities.. youll have to spend like 100-115 for an oil change, 35 maybe rfor fuel water seperator, bigger oil filters, more trans fluid for trans service, and if your doing short drives in a turbo diesel you might want to change your oil alot more often then every 3k miles.. its really bad for a turbo diesel to just make short trips. glow plugs usually last forever on those.
Garon
86
January 30th, 2020 10:00 AM
smithk3933
May 22nd, 2008 4:39 PM
