Last edit by: IB Advertising
- Chevrolet Silverado GMT800, GMT900, and K2XX Why Don't Power Door Locks Work
Guide to diagnose trouble and recommended solutions.
no power door lock,no power windows,mirror remote stopped workin
#31
I've got a 2008 Chevy Tahoe that everything on Drivers door handle is NoN - Functioning? I've checked the fuses for DDM, & PDM all are good, cleaned the switch housing, and contacts inside the switch, and still nothing is working? Hummm
#32
Passager side door
My passenger side power window n door locks won't work but the mirror turn signal does work. This is in my 2003 Chevy avalanche. I just replaced the window motor with one that works but still nothing I've tried a couple different door switches but again nothing. Plz help
#34
My 2004 Tahoe driver door suddenly lost power to everything. I have power to the switch via the 4 prong connector at the front of the DDM. I have replaced the DDM with no change. @Chevrolet Customer Service can you please give me some guidance on what to check for next? Any input from any user is greatly appreciated.
#35
07 Driver door window/lock/mirror not working
Hello, I have an 07 Tahoe LS. My driver side door handle module has completely stopped working. Before the door would stop working when you had the door open but now it doesn't work at all. I checked all the fuses under the hood and in the left part of the dash. I even checked the single fuse on the back of the module that holds the fuses. It was fine as well. I have read that people have had others check the relays. Swapped relays and nothing has changed. At this point I am wondering if it is Software related, Module related, or controller related. I need help with the issue cause at this point I am at a lose.
One quick side note, this Tahoe is an Ex Boarder Patrol vehicle. The ECU still has the tune from when it was an Active Law Enforcement vehicle. I don't think that would play a factor in any of this but any side piece that are computer related I thought I might jot down as it might aid someone in helping find a solution to this issue. Chevy CSR can you help please?
Chevrolet Customer Service?
#36
#37
08 rear windows wont roll down and doors wont unlock
the rear windows will not roll down i can hear a click when i use the switch to roll up also rear doors wont unlock with fob or door switch but will lock with the fob and switch.
#38
Please help
Yes I’m have an issue with my windows. 2001 Chevy Silverado 1500 base model extended cab 5.3. Can’t get windows to roll down or up no mirror power not power to driver side mirror or window motor. Only power on drivers side is to the door lock. I’ve replaced the window motors and switch’s still nothing checked fuses again still good. Really needing help have a 2 year old with no a/c currently. ~Jordan~
#39
Girfriend1
I see this is a common problem with the door locks, mirror and door light not working on one door... mine being the drivers door. This started with the key FOB slowly not working. I disconnected the battery for a couple of hours, and to my surprise everything worked fine again. That is until I got home and when I put the truck in park, the drivers door did not unlock. Back to square one. Tried disconnecting the battery again... no luck. Does anyone have a fix??? This is very annoying!
