OBD codes
Old Dec 8, 2009 | 7:52 AM
jameseroot's Avatar
Default OBD codes
03 silverado Z71 5.3 4x4 200,000. she is throwing a couple of codes. i have the codes and know what they mean, but need to know how to fix.
P0430 cat, below threshhold, bank 2.
P0171 system to lean bank 1 and 2.
any help in where to start would be appreciated. thanks
Old Dec 8, 2009 | 6:10 PM
dmann13815's Avatar
system too lean on both banks usually means feul delivery problem, first place to start would be a new fuel filter and clear the codes. If the problem persists then check your fuel pressure, could be a fuel pump going. About the catalyst, hope the fuel issue resolves both of the codes because then your looking at replacing the cat.
Old Dec 8, 2009 | 7:16 PM
jameseroot's Avatar
i haved replaced the filter about 25,000 miles ago. will check fuel presure and post results. thanks
Old Dec 8, 2009 | 9:34 PM
MDTAHOE's Avatar
Professional Mechanic
On the 5.3 most likely you need intake gaskets. Fix the codes for lean first if the other comes back you need a cat. PO171 is system too lean bank 1 sensor 1 PO 174 is system too lean bank 2 sensor 1Did you have a PO174 also?
jameseroot
Dec 9, 2009 4:38 PM
Retiredphoneman
Apr 29, 2009 12:05 PM
ladagosta
Dec 9, 2007 12:06 AM
shnormo
Feb 12, 2007 12:10 AM
shnormo
Feb 12, 2007 12:09 AM
