Please help sputtering
Old Jun 4, 2008 | 8:25 PM
dariverrat's Avatar
Default Please help sputtering
OK here it goes... I just replaced the, Fuel Pump, Fuel Filter, fuel injectors, fuel pump relay, spark plugs, wires, coil, distribuator modulator, coil pick-up, and the on board computerECM. !!!
Now here is the problem, while driving between 10-20 mph at an even steady pressure on the gas pedal there is a chuging and sputtering, let off gas and puh puh sputtering then clear idle, or if I give a little gas pedal pressure it smooths out and goes... Please before I spend any more money on this worktruck (210,000miles on her) what can it be????
Thanx in advance for the info
Old Jun 4, 2008 | 11:51 PM
northey87's Avatar
Default RE: Please help sputtering
Some more info would help, model? year? engine?....?
Old Jun 5, 2008 | 5:32 AM
dariverrat's Avatar
Sorry for the lack of info on vehicle.
1992 Chevy Silverado C-1500 extended cab 2 wheel drive 350 motor w/air,
Old Jun 5, 2008 | 11:20 PM
northey87's Avatar
Not quite sure what could be wrong, maybe the ERG?
Old Jun 17, 2008 | 7:04 AM
BurninRubber92's Avatar
Perhaps it could be a spark problem. Check the plugs for wear, and replace if needed. Change the plug wires depending on how long it's been since they've last been changed. every 50,000 miles is a good rule. Also, one more suggestion, if you have the tools check the timing.
I know these are obvious suggestions, but sometimes the obvious is what's overlooked. Hope this helps.
brothers4.3
11
Sep 23, 2014 8:35 AM
WMfball2007
Nov 9, 2010 10:57 AM
Rustybolt
Apr 28, 2009 7:43 AM
96GreenMonster
May 10, 2008 8:32 PM
zgcruiser
Apr 24, 2008 8:05 AM
Top
Follow Us
