Plug wires
Old Feb 17, 2007 | 12:10 PM
02HD's Avatar
Default Plug wires
Moving up the line to resolve a cold start/misfire problem. Is the quality of the aftermarket products as good or better than oem ? Advertising is just that. Experience is priceless. Anyone want to share some of the later ?
Old Feb 17, 2007 | 3:34 PM
shnormo's Avatar
Default RE: Plug wires
I like Accell, MSD, and Taylor wires. Nappa has good wires also.
Old Feb 17, 2007 | 4:35 PM
02HD's Avatar
Thanks.
Accell and NAPA are old friends. MSD and Taylor have never made under the hood for me. No particular reason other than just not being readily available locally. I'm looking for a fix to a cold start problem. Enginestarts well and will run good for about 30 seconds or until the idle begins to drop below 1000. Then begins tomiss, sometimes it quits completely, not always. As the engine warmsit begins to smooth out and run fine. This only happens at about 30 degrees or less. So far I've replaced the plugs and added lots of injector cleaner to the fuel. Results : No improvement.
Old Feb 19, 2007 | 7:33 PM
02HD's Avatar
Any Ideas ? Anybody. Plug wires replaced yesterday. No joy.
Intake gasket leaks or bad injectors ?
Old Feb 19, 2007 | 8:05 PM
shnormo's Avatar
Run Lucas Upper lubraction/fuel injection system cleaner. Then run sea foam through the brake booster vaccuum and clean out the throttle body with some throttle body cleaner. That should help a lot.
TPM
May 14, 2013 5:58 PM
Nags
Mar 29, 2008 1:23 PM
LyleD
Mar 5, 2008 9:43 AM
pete_dallas
Mar 3, 2008 12:07 AM
chevykid06
Dec 28, 2006 10:43 PM
