power booster+ master cylinder
I need a lot of help, I have a 69 C10 Pickup (350Motor). I am trying to purchase a Power Booster with Master Cylinder to suit my truck. Is there anywhere i can find a part number for the booster?? as i have purchased 2 boosters (bought through Ebay) and both boosters will not fit my truck. The problem is, the connection from booster to firewall, One booster has a completely different bracket and the other has a lot smaller bracket. At this rate it might be cheaper to buy a new truck, as these parts are not readily available here in Australia, maybe someone can give me some info which will make it easy for me to buy the exact booster that i need. Any time i do a search on boosters all i get are Brand names, which state that they will fit my model truck but when i see a picture, there is no way that they will bolt onto the firewall. So if someone has any info that will help me purchase the correct booster it will be appreciated.
screw that man. 1969 had drum brakes front and rear. that car is a sled. Why dont you upgrade and save yourself the hassle? You already have 2 brake boosters. And in 1969 the firewall is a simple stamped piece of sheetmetal. So is the dash. Why dont you just drill the extra holes into the firewall to get the booster to fit, attach a longer brake pedal and convert to disk brakes? If you re in a different market sometimes you have to be creative.
LMCtruck.com will have that stuff but then again all brake systems are pretty much the same, you can go to your GM place there, Holden or whatever you guys call them. Even Ford can get you a brake booster.
jason78
April 13th, 2014 2:40 PM
jasonthatsme
15
August 6th, 2013 7:24 AM
qzack1
August 28th, 2011 12:50 PM
randys94
May 14th, 2009 9:39 PM
