Power driver seat and pass window not working checked fuses...what next?
I have a 2003 2500hd with the 8.1L. Yesterday the pass window and driver seat, both power stoped functioning at the same time. Naturally i assumed that it was a simple fuse, but after checking and double checking all the fuses i have had no luck in resolving the problem. I am looking for any help and guidance as to what i need to check next. I don't believe that it is a switch or such since both stopped working at the same time and neither window switch operates the window. Kinda sucks cause the window is stuck down. any help greatly appreciate...before i have to go to the $tealer.
RE: Power driver seat and pass window not working checked fuses...what next?
If you pull your door panel off you should be able to get your window up buy jumping the wires that make it go up. I can't tell you what wire those might be though.
ORIGINAL: weside
check under the seat for broken or chaffed wires
As far as jumping the wires to get the window back up then you don't have to pull the door panel off. Just pop the pass. window switch off and I beleive it's a purple or a yellow wire that you need to jump to a black wire. I can't remember exactly what color.
greg86jgl
December 13th, 2011 8:38 AM
buijon
June 5th, 2008 9:30 AM
lacelles
July 12th, 2007 10:35 AM
