Power window motor replacement
I have a 2002 silverado crew cab and the right front window motor has gone bellyup. I have it half removed and can't see how to disconnect the motor from the maze of cables, and drive mechanism. Doesany one know where to find instructions on replacement, or does anyone have any suggestions?
Do you have it loose and hanging? I am going to assume not. Reach behind and see if you can feel any rivits or bolts holding it in. Other than that it's just disconnecting the wires that bolt to it.
Hi KCB37
Yes I do have it hanging . I can see the motor shaft where it goes into drive mechansim, but it will not come out
I am wondering if the motor is replaceable or will I have to replace the motor and drive together.There is a maze of drive cables connected to the drive mechansim. (NIGHTMARE). I can usually figure this kinds of things but this has me stumped. I sure would appreciate any info you can give me.Thank you for responding.
kardan
October 2nd, 2009 9:59 PM
melat70
August 11th, 2007 11:38 AM
ake11
June 29th, 2007 1:36 PM
werre7300
December 24th, 2005 5:28 PM
