Last edit by: IB Advertising
See related guides and technical advice from our community experts
- Chevrolet Silveardo GMT900 How to Flush Radiator
Step by step instructions for do-it-yourself repairs.
Radiator Drain Valve (petcock)
I am soon going to flush & replace my coolant/anti-freeze in my 2004 Silverado 1500 {5.3L V8}. When I looked under the hood, I did not see the drain valve. Is it hidden behind the fan shroud or something? Jeez!
I don't much like it when things are not where I am accustomed to seeing them on other vehicles. Where is the dang thing?
** En vino veritas. **
check at the bottom of the radiator on either side. should be at the lowest point of gravity. if you cant find it. invest in a chiltons manual or disconnect your lower radiator hose.
Yep; I may have to go that route. The hose doesn't look as though it would be very hard to remove - and the clamp is acessible.
Thanks!!
domano 68
January 24th, 2014 7:26 PM
peterz
April 22nd, 2007 8:05 PM
