Radiator keeps developing leaks!
Radiator for 1998 Chevrolet Z71 pickup keeps developing leaks. Have replaced radiator several times. This last one lasted approximately one month. Gas mileage is low, but power seems okay.
if they keep gettin leaks..shouldn't you check for something that could be causin it? it's the actual radiator that's leakin and not the hoses runnin to it?
As this poster i quoted said, look for exactly where it is leaking.
Make sure the retainers that hold the aux oil cooler and the transmission cooler inside the end caps are tight, my 97 Tahoe developed a leak there, tightening the retainer nut resolved the leak....
Make sure you are properly purging the system of air, too much air can make it run hot and can damage the radiator along with the engine as well.....
make sure the rubber bumpers are in place when you install the radiator as they provide protection from abrasions as well....
once last thing, make sure you are using the correct radiator cap, if the system is over pressurizing it can cause leaks, if its the original cap replace it...
Have already checked these things...radiator cap has been replaced, all mounts are correct. Leaks are in various places, usually towards the center, not the same place every time. Has anyone ever heard of a catalytic converter causing this? Also, I have replaced with aluminum radiators and not copper.
These radiators have all been new. Have not done a complete flush of the cooling system, but intend to do so with this replacement that I am doing today. Will also look at the overflow reservoir. Thanks for the help. Any other ideas?
Last edited by Ray98Chevy; August 6th, 2011 at 9:43 AM. Reason: need to add something
I'd say use a good quality flush such as prestone, and follow the directions. If the flush water that comes out is nasty looking, don't hesitate to flush it again.
Damato
February 16th, 2015 5:19 PM
raweggfarts
October 21st, 2014 7:55 AM
skidplate
June 19th, 2006 1:10 AM
