Random misfire code after running out of gas
Hi, I have a 2000 silvy 1500 and I’m having trouble diagnosing a random misfire. I was on e when I shut the truck off and it wouldn’t start so I put more gas. Had trouble starting but eventually started, first it threw me a cylinder 2 misfire, put heet in the tank and cleared it. Now it throws a random misfire code. Weird thing is that it doesn’t sound or run any different. I replaced the fuel pump thinking it might have been weak but same problem. Maybe a fuel filter or injector? Any tips? Didn’t go as far as coil packs or plugs just because the codes started after I ran it on e
I'm guessing the the SES light is or was flashing and maybe on steady with a P0300 set. Knowing what cylinders are showing mis fires and when ( all the time, at idle only, under load, etc.) could be helpful. If you know what cylinders. you can start by swapping coil, plug and wire to a cylinder that isn't having an issue. Can also do an injector balance test. Just a quick thought .
dball30
Oct 24, 2022 7:16 PM
