Refrase: What is the best oil to use?
#13
ROTM Coordinator
ROTM Coordinator
You did nothing wrong, its a common topic that gets old to some people, thats all
We post so you get other opinions like you inquired about, I hope it was helpful & informative.
![Wink](https://chevroletforum.com/forum/images/smilies/wink.gif)
#14
ive seen MUCH better results with synthetic oil in my 4 bangers shoving 500+ HP out of them than conventional oil, as far as brands go, ive tried them all in the little motors and they have all worked well EXCEPT royal purple is garbage.ive had 2 engines magically wipe out bearings on that stuff, and the trans oil is like **** water and burns up gears. the rest, be it redline, amzoil, valvoline, mobil1, penzoil, ect. any full synthetic has held up well.
My top pick is redline oil, but its not so easy to find. for your truck, like they all said, any given full synthetic is fine. GM's factory fill on the vettes and cars that come with synthetic is mobil1. use whatever you like. IMO stick with an AC delco filter.
#15
ROTM Coordinator
ROTM Coordinator
![Confused](https://chevroletforum.com/forum/images/smilies/confused.gif)
Iam not debating oil , I just would like to hear your feedback
![Smile](https://chevroletforum.com/forum/images/smilies/smile.gif)
#16
I've had three motors blow in the time I've been driving. One was a 4.3 that always ran on 10w30 pennzoil conventional. The other was a 454. It always ran on 10w30 pennzoil conventional. The other was a 3.1L GM that always used pennzoil conventional 10w30. I kinda got the picture after the second engine blown. I now use synthetic. I recommend synthetic to anyone who changes their oil (be it taking it to a shop or DIY). I use valvoline synpower. I have used mobil 1 synthetic on my second 4.3 and put over 100k on it changing it at 5k IIRC with no problems, engine wise, and I ran the crap out of that little motor. So really, Synthetic is the only thing I say to get, brand is up to you. Never heard anything bad about RP, by the way. My uncle uses it and changes it at 12k and has used it for about 50k so far.
#17
Really? how long was the interval when you changed it? I am using it for the first time( engine only) and would like to hear from others that have used it. Never herd that before
I plan to go no more than 5,000 mi on it( all oil gets dirty after a few thousand miles), it has 2,500 on it now and its still clean. I dont run the **** out of my motor though, I drive it how its designed to drive.
Iam not debating oil , I just would like to hear your feedback![Smile](https://chevroletforum.com/forum/images/smilies/smile.gif)
#18
ROTM Coordinator
ROTM Coordinator
lol, well that explains most of it.
I am only pushing 45 hp per cyl @ 4800 rpm and thats rare for me to do unless I am passing someone.
I wonder if RP has some kind of dye in it to make it purple, but it seems it goes clear after its used a little bit, my dipstick does not look purple like it did when I poured it in.
Peter Wolf
May 11th, 2010 1:55 PM
northey87
15
January 3rd, 2009 9:41 PM
