Replacement of stereo
I recently replaced my stock stereo with a new Pioneer after market stereo in my 2005 Silverado. I found the wiring diagram for the truck and connected the wiring harness to the new stereo accordingly. The new stereo will not come on. I read that you may have to take the truck to the dealer to have the reprogram it to accept the new stereo. Is this correct? i cannot figure out why te new stereo will not turn on.
Hey Eddie,
Do you have power going from your ignition to the stereo? What I've found is tapping into the red or brown ignition wire near the steering column and running a jumper into the red power wire on the stereo wiring harness. Also have you turned on the ignition or truck and used a voltage tester or meter to see that there's power at the power wire on the stock harness?
I will try that
Hey Eddie,
I don't believe so. In my 04 1500 and 05 2500 I replaced the stereo both times and didn't have to take it to the dealer for a reprogram either time. I know the yellow wire should be your constant to retain power and the red wire is your power to turn it on.
The part about taking it to a dealer is if you were placing a different GM radio into your vehicle. They would then program your VIN number into the radio. It is part of their anti-theft program.
I would check for proper voltage at the radio.
Good luck
Bill
Good luck
Bill
