ROARING IN FRONT END
I HAVE A RORING NOISE IN THE FRONT END OF MY 2005 CHEVY K1500 Z71 CREW CAB. IT IS ESPECIALLY NOTICEABLE AT SLOW SPEEDS. IT SOUNDS LIKE A GRINDING AS THE WHEELS ROTATE, ESPECIALLY AROUND 30-40 MPH. I'M NOT SURE IF IT'S IN THE WHEEL BEARINGS OR THE FRONT END DRIVE SHAFT AXLE JOINT. ANYONE HAVE THE SAME PROBLEM???
I just recently had the same problem. I could hear it more though when in a turn but only in auto 4wd or 4wd. Turned out to be the bearings in the front diff.
