Rough Ride..
Rough Ride..
Hey,
I have a 93 Chevy 1500. I has a 4in body lift and 33's on it. how can i get a smoother, less jaw rattling ride out of it.
RE: Rough Ride..
let some air out of the tires......that will help a bit, dont know what your running your 33 for air pressure, but I run mine on my jeep around 15-20 around town and 8-10 off road, the difference when I air them up over 25 is horendis........under that its like night and day, that may help a bit, if you have them air up to 30+.........by nature the GM are a very smooth ride as compared to Ford and dodges.
The 4 in BL is not helping and that is ALOT of BL, your body is prolly moving around on top of hte pucks, how did you get a 4'....?...no one makes one I did not think as they are not recommended over 3..and that is not good...if it is not qaulity lift 'blocks' and someone or yourself used 'pucks' or soemthing else, it could be these are beat out and the bushings are gone, and may need changed....
Shocks could help, but normally when they go your truck will 'float' so to speak....Im guessing it can all betraced to the BL you have and the crappy 'pucks'someone used.
RE: Rough Ride..
so basically, check the body lift which might be a 3...ill have to check, and run my tires low? around 15-20? what where you talking about running 30 +??
RE: Rough Ride..
ORIGINAL: mudderfan
the body lift will make it a bit rougher but not so much you should complain, unless someone used 'hockey pucks' to lift it, and did not put good rubber bushings in....also is it a Z71 cause they ride rougher on highway as well, they are ment for gravel and bush roads, cool decal tho.....
