Service 4WD
![Exclamation](https://chevroletforum.com/forum/images/icons/icon4.gif)
So the first two lights of the button module on the dash went out. Then the message read "Service 4WD", then all the lights went out. I then bought a new button module, because I know these tend to go bad a-lot.
I swapped the old out for the new, and the buttons all lit up. But, the message still read "Service 4WD" so then I was told that you have to unhook the battery for 15-30 minutes, so I did. Hooked the battery back up message was gone then I realized that the indicator light was not lighting up. I drove around the block to see if although the light wasn't working, the 4WD was. The 4WD was not working.
Any suggestions anyone?![Frown](https://chevroletforum.com/forum/images/smilies/frown.gif)
2002 Chevrolet Silverado 1500 5.3
Thanks. It turned out to be the ATC fuse. After searching the Internet for someone with the same problem I found a list of fuses to be checked, and that one was bad, put a new one in and BAM all better!
abj182
August 5th, 2015 8:58 AM
D Chevy
September 17th, 2012 12:06 PM
waller2003
October 19th, 2009 9:49 PM
DianaT
November 29th, 2007 12:12 AM
