Service break booster?
Old February 16th, 2008 | 11:43 PM
  #21
northey87's Avatar
Default RE: Service break booster?
Doesthat cylinder have a line that runs between the it and the booster? If is does that cylinder may be part of the ABS and the noise your hearing (a vibrating hum)may be the ABS applying itself needlessly. Does the ABS light come on while its make the noise?
Old February 16th, 2008 | 11:56 PM
  #22
jermacjr's Avatar
No line between between the two, Thats the wierd thing, i can't figure how the two are related. theres just the wire harness on the top and the vacuum line that runs behind the manifold.
Old February 17th, 2008 | 12:02 AM
  #23
06chevy5.3's Avatar
it looks like its bolted onto where the regular booster hose is supposed to be, is it?
Old February 17th, 2008 | 12:09 AM
  #24
northey87's Avatar
Is there another vaccum line running to the booster?
Easy way to test, if it is a vaccum line (if not, or not sure then don't try this)then disconnect it and plug the end, run the truck and see if the brakes are stiff. If they are then they are connected, if not (and braking is normal) thenthey are notrelated.
Old February 17th, 2008 | 12:43 AM
  #25
jermacjr's Avatar
06chevy5.3, Yeah, its mounted right there. After checking closer, itIS attached to the booster, behind it theres a small fitting going into the booster with a rubber gasget sealing it. I think northy87 was on to something when he said it was for the abs. Might have to break down and go get a manual tomorrow. northy87, I'm not totally sure that its a vacuum line, I don't what else it would be though.
Old February 17th, 2008 | 12:59 AM
  #26
northey87's Avatar
Its got to be. Thats where the booster gets it power, and that cylinder is probably what lets up on the brakes so they don't lock up when you slam on them.
Old February 17th, 2008 | 1:05 AM
  #27
jermacjr's Avatar
Thanks again for all the help guys, I really appreciate it. I gotta check out for the nite. See ya.
Old February 19th, 2008 | 4:33 PM
  #28
jermacjr's Avatar
F.Y.I. The part is called a booster auxillary pump. Basically its a a check valve.the wire harness on the topis simply therefor the ecm to moniter the booster.180.00 dealer only part , 20 minute install.Thanks again.
wtroger
Avalanche
May 30th, 2021 1:08 PM
DMaxEnvy
April 17th, 2011 11:40 AM
sierra_5300
December 9th, 2010 10:32 PM
GSXJuggalo
September 17th, 2007 8:36 PM
Hbhalibut
June 8th, 2007 8:47 PM
Quick Reply: Service break booster?
Top
Follow Us
