Shakey front seat
The right front seat in my 2000 Seirra has play in it. When you hit the brakes it moves slightly forward and then back when you hit the gas. I have inspected what bolts I can see and they all seem to be tight. Any ideas on what it could be or how to tighten??
Hi, I have a 98 2500 extendened cab... mine does the same thing. If the bolts are tight, the play is most likely in the seat track. I found mine that the track and rollers were worn causing the seat to "rock" when stopping and starting. See if you can find a good used seat tracks and replace them........good luck
Davidc21a
May 8th, 2018 7:29 PM
mchgnmike
November 11th, 2010 3:22 PM
