View Poll Results: silverado shuts off and on at hwy speed
reolaced VSS on tanny
![](/forum/images/kirsch/polls/bar2-l.gif)
![](/forum/images/kirsch/polls/bar2.gif)
![](/forum/images/kirsch/polls/bar2-r.gif)
![](https://chevroletforum.com/forum/clear.gif)
0%
replaced wheel speed senser
![](/forum/images/kirsch/polls/bar3-l.gif)
![](/forum/images/kirsch/polls/bar3.gif)
![](/forum/images/kirsch/polls/bar3-r.gif)
0%
what could cause this
![](/forum/images/kirsch/polls/bar4-l.gif)
![](/forum/images/kirsch/polls/bar4.gif)
![](/forum/images/kirsch/polls/bar4-r.gif)
0%
Voters: 0. You may not vote on this poll
Replaced the varible speed senser because Truck cuts out like its shutting off and on .,after replacing the one on the
transmission still doing it also engine check light comes on have it read says its the VSS intermittant any one know whats
causing this
causing this
- reolaced VSS on tanny
- replaced wheel speed senser
'"vehicle" speed sensor
could be faulty wiring
I have replaced the vss and the connector it still cuts out once and awhile when it does the gas gauge goes to emty and stays there until all of a sudden it will go back up any ideas whould be helpfull
Please provide full details on the truck - year, engine, auto/manual, dual tank, etc.
2013 siverado ltz 4x4 single tank the speed om move back then back to correct speed gas gage goes off and stays off for sometime low fuel light comes on
Its a 2013 chevy silverado 1500 excab LTZ 4x4 auto tran 5.3 eng when driving it acts like it shuts off and on door locks click speedometer drops back then back to correct speed cruize bo longer engaged sometimes check gauge goes to empty and stays there low fuel light comes on show gas stations on stereo have replaced the VSS and the connector, It will go for a long time then all of a sudden jerks like it shut off and on code is P2161 Vehicle Speed Sensor 2 Circut Intermittent secondary DTS NO CODE
The instrument cluster and gauges (IPC for short) are 100% data fed and logic controlled. All the gauges, indicators and other information are prompted by other control modules via the data network and the IPC simply responds to the requests.
The fuel level is actually monitored by the ECM and the ECM tells the IPC what level the gauge should read.
The VSS is monitored by the TCM (or PCM if no TCM) and the TCM tells the cluster what speed the gauge should read.
For the cluster to be cutting in and out, combined with the stalling, suggests the loss of communication. Generally speaking this should trigger a related DTC in the ECM, but depending on the nature of the problem that may not be the case.
However it could also be a faulty battery that’s draining the electrical system even when the engine is running.
At this point I have 2 recommendations:
1) Take your truck to a shop for a full system scan. This will check every single module for codes that may provide better direction for determining the source of the problem.
2) Try a battery cable reset and see what happens. Disconnect both negative and positive battery cables and connect them with a pair of vice grips or a jumper wire for at least an hour, then reconnect and test drive.
In a 2020 High Country with approx. 30K miles (two northeastern winters); I noticed a variety of what appeared to be unrelated electrical problems. Upon further investigation, I found a faulty ground strap located behind the passenger front tire and 6 inches up from the bottom of the firewall. Yeah, what a stupid place to attach a chassis ground strap. The strap was braided and about 12" long with crimped islets on either end. It was replaced with a flexible number 4 welding cable and two soldered copper ring islets. I sprayed the lower islet with Fluid Film and that was the end of the electrical problems.
Best of luck.
Best of luck.
![Question](https://chevroletforum.com/forum/images/icons/icon5.gif)
I’m not familiar with this specific code so I’ll need time to research. However, the issues you describe are more indicative of a general power and/or ground supply problem; or a communication problem on the high speed network.
