Silverado starting problem...
#11
Try hitting the tank a few times with a rubber mallet while someone is cranking. If it starts you need a fuel pump. Try spraying carb cleaner in a vac line or into the t-body (you must have the air tube pretty close) while someone cranks it. PCM B fuse is the power into the fuel pump relay. You most likely have a bad pump.
#13
It will start spraying starting fluid in the throttle body, but not stay running. Beating on the gas tank while someone cranks it has no effect. How would I go about testing the fuel pump before I have to drop the tank?
#15
If your under the truck when someone turns the key on you can feel the fuel pump buzzing.still think its the fuel pump? Sorry, just would hate to go through dropping the tank and spending $250 on a new pump without being pretty sure. I guess i am just still worried it could be a security system problem, mostly because the security lihht never comes on at all.
fire165
11
August 23rd, 2011 10:29 PM
Laketruck
March 19th, 2008 4:48 PM
dude1987
October 21st, 2007 11:05 AM
ffarv
April 9th, 2006 1:52 PM
