Silverado transfer case will not disengage
I've got a 1999 Silverado Z71, 5.3.after the last big snowfall,and numerous days in 4hi .i noticed abit of vibration and more noise coming from front end of the truck . after some investigation i realized the transfer case is still engaged even though the dash selector says its back in 2wd.it will still switch to 4lo .any help would be greatly appreciated, thanks
yea i tried neutral .it releases the front diff.but the transfer case and front drive shaft are still turning with the transmission.i actually needed the 4wd we had 30 inches of snow and it took road crews almost 4 days to get all cleared.i just didnt realize that the trnsfer case wasnt disengaging as the dash indicator shows 2wd
ahh... well, it might've toasted something. Driving around in 4hi a lot can do bad things. I try to stick to 4lo unless I really need the extra torque that 4hi gives.
bsball, I think you're getting the two confused. 4hi is what is used most of the time while driving around, 4lo really drops it down and doesn't allow you to drive very quickly.
Unplug your battery for awhile and hook it up and try it again. My buddy has a similiar to mine and he hit a mud hole and it did the same thing. We unpluged the battery for awhile and hooked it back up and hasnt acted up since.
ledjr857
June 5th, 2015 10:49 AM
machttt
May 1st, 2014 10:57 PM
JoeBlow
11
April 27th, 2012 11:08 AM
