starting issues like battery is dead.
#11
I tried to replaced the bolts but they do not seem to come out,they just trurn and turn. I cleaned the bolts and connector really good and thet did not make any diff. Went to Walmart and got a new battery,for some odd reason the battery that was there was only showing 6.5V after driving it for a while and then it would not start again. Got the new Batt it was more than 60 months anyway,fisrt attempt to start it=same problem ,but then I was able to started right up with out any hesitation. I will eventually replace the bolts. and go from there.
#12
(N)everstart battieries are not a wise choice. You will have issues when you try to warranty it out. Have a charging system diagnostics checked out on it, sounds like a faulty diodes/regulator in the alternator.
#13
Professional Mechanic
My guess is the battery bolts were severely corroded the the battery( that is why you could not get them out) (very very typical). Walmart forced it apart and cleaned the bolts slightly then put them back in your NEW battery. This will only result in the same problem again in a few months. Corrosion grows like mold. If I were you I would disconnect the cables and take a look.
ygom3z1992
February 10th, 2015 10:41 AM
MichaelJAwesome
June 14th, 2010 8:00 AM
