Steering problem
Steering problem
Hey everyone. I just replaced my inner tie rod ends and shocks/struts this last weekend (and also took off the relay rod because I was going to replace idler and pitman arms as well but ran out of time) and got an alignment after the job was done. The steering feels fine, except when I crank the steering wheel all the way to either side (like in a parking lot), it feels like the front tires want to "slip" and go straight rather than turn, which causes them to squeel. I thought it would be an alignment issue with toe in, but that was all adjusted.
Is it possible that if I over or under tightened the relay rod it would cause this? My power steering fluid level is good and gear box has a very small amount of play (like 1/32 inch) which isn't new. I thought it might be the power steering pump, but that wouldn't explain the tires "slipping".
Details on truck: 1999 Silverado 1500, 4x4, 150k miles, BFG All Terrain tires with about 30% life left.
Any help is much appreciated, thanks!
Hi azchevy99,
Welcome to the Chevy Forums.
I moved this to the Silverado section and posted so it would get the specific attention it needs by those familiar with your vehicle.
I believe(may be wrong) that a "pop" ateither extreme end of steering play may be a common(although minor) failing in these particular vehicles...
bobbygrady
August 14th, 2013 8:57 AM
w002mia
June 29th, 2013 3:27 AM
w002mia
March 18th, 2013 11:42 AM
cyberrkatz
January 31st, 2011 8:54 AM
ray9295
April 2nd, 2010 3:46 PM
