suspension question. need help!
Old April 4th, 2010 | 2:01 PM
madkat400's Avatar
Default suspension question. need help!
i am the proud owner of a 2002 silverado 2500 4x4. i'm looking in to getting a mild lift. probably just 2 inches. with some 32 inch tires. but i'm having problems finding a lift for my application. most of the lifts are for HD models. my question is are the lifts interchangeable between hd and non hd models. specifically the torsion keys? any feedback or help on where to look would be appreciated
Old April 4th, 2010 | 2:51 PM
s34n's Avatar
the torsion keys should be similar between the two. check out rough country leveling kits. and with those you can fit 33s on. im going with 285 tires which are equal to a 33 inch tire. if you go with rough country i'd order new shocks just so that you can get close to the same ride as you had before otherwise if you just crank the t-bars. your ride will be stiffer.
Old April 4th, 2010 | 3:06 PM
992door's Avatar
Yea you can crank your torsion bars to level it out and run 33's
Old April 4th, 2010 | 3:57 PM
madkat400's Avatar
i appreciate it, that helps out alot. i checked out rough country and liked their kits but they didnt say they were for non HD models as well. thanks for clearing it up
Old April 4th, 2010 | 4:04 PM
s34n's Avatar
your welcome. hope all goes well. im sure you could email them and ask them if it works for the non hd model.
Old April 4th, 2010 | 4:08 PM
nauticstar87's Avatar
You cn crank the T-bars, but the ride will be rougher. Trust me. i didn't notice it at first.
Simon-Pierre Lacasse
March 8th, 2014 7:18 PM
john4a73
December 5th, 2012 1:27 AM
akabavah
Avalanche
October 10th, 2009 9:54 PM
FriscoKid
January 23rd, 2009 9:36 PM
john4a73
April 22nd, 2007 8:14 PM
Quick Reply: suspension question. need help!
