tbi 350 getting WAY to much fuel
howdy everyone, new to the site, i have a 1989 k1500, reg cab short bed, tbi350 5 speed. i was crusin down the road one day and she shut off. wouldnt start back up. kept flooding its self out. since then, i have installed a new fuel pump and sending unit/w pump. throttle positioning sensor, coolant temp sensor, new fuel regulator. still way to much fuel. the only way it will even start, is if i unplug both injectors, turn it over an let it run for a sec, then plug one injector in at a time, it will start, then i can plug the other in, it will rev up wont idle, still flooding out. im starting to run out of ideas. any help is awesome!
yes ive completely rebuilt and cleaned the throttle body, and yes i have changed the oil, that wouldnt have anything to do with my problem because its pouring out of the injectors too fast
was this ever solved?
I'm having exact same issue. I've replaced the injectors, the fuel pump, the regulator, the forward temp sensor, tested the map and tps which are both good. Fuel psi is 11. Still won't start.... also new plugs, wires, cap, rotor, verified correct wire placement, verified spark, not sure what else to do.... also verified wire paths back to ecu.
Fixed?
did you guys ever figure out what is going on with your trucks? I have an 1988 that has the exact same problem. Done everything you guys have.
thanks!
thanks!
simpsonracing
March 19th, 2013 3:37 PM
geozeke
October 19th, 2009 3:17 PM
