is TFI to Carb convert possible?
Old Nov 5, 2012 | 8:06 AM
jesse06's Avatar
Default is TFI to Carb convert possible?
I have a 1988 K1500 350 with the fuel injector carburetor. Can I remove the entire idle air controller module, fuel injector carburetor and replace it with a older non electric carburetor that works on jets, floats, and a cable operated choke ?
Old Nov 5, 2012 | 10:28 AM
Allan In NE's Avatar
Sure,
Welcome back to the world of burnt valves, egg-shaped cylinder walls and lousy fuel efficiency.
Allan
Old Nov 6, 2012 | 8:21 AM
McBob's Avatar
Default +1
Sure, piece of cake. The only real thing to deal with is that the fuel pressure is lower so you'll need a different fuel pump. You cap off the return line to the fuel tank, drill holes for the choke cable, and so on. Pretty straightforward.
You'll need a fuel pump and some basic stuff to do your throttle linkage. These things might even be included in your carb kit. Really no big deal to do.
And you'll see an immediate decrease in performance, drastic reduction in fuel economy, shorter engine life, all the great stuff that pure mechanical fuel systems are known for.
Old Nov 8, 2012 | 8:18 PM
jesse06's Avatar
ahh, so it'd be a down grade from the TFI carb... Looks like just rebuilding whats in it is the best thing to do.
Old Nov 9, 2012 | 6:34 AM
shamrock246's Avatar
What problem are you haveing?
longyard
Aug 4, 2011 7:03 AM
Delta Motor AG
Sonic (Aveo)
Oct 24, 2007 8:57 PM
TheYeti1775
Oct 22, 2007 1:49 PM
texas patriot
Oct 17, 2007 1:07 AM
shnormo
Feb 12, 2007 12:54 AM
