Time to get tires what should i get?
#12
Is having the stock keys all the way up the same amount of stress as the leveling keys all the way up? Or are the leveling keys worse? Reason I ask is cause I was thinking about putting a slightly bigger block in the rear.
#13
Stock keys cranked up are easier on the front end, though not great for it either. Levelin keys are re-indexed for more lift but is way worse on the front end. I'd recommend on levelin keys if your t-bars are worn out, or you can't get it level with the rear as of now
#14
Okay, that's what I was thinking but wanted some one else's opinion. I know you then recommended the 1.25" body lift also? Is there any reason you don't recommend a bigger body lift and with that 1.25" you don't have to extend anything meaning wires connections etc. Do you? Doesn't effect steering any?
#15
I recommended a 1.5" because it doesn't show near as much frame and looks cleaner IMO...and no you don't have to extend any wires or lines. Steering isn't affected, you don't even need a steerin extension
#18
Did you get the rear bumper bracket? Reason I ask is since its only 1.5" I was just wondering if it even looked that bad without the rear bumper brackets?
#19
Yeah I ordered it, I seen a pic of it not on there and it looked funny IMO. The bumper just doesn't line up with the back of the fender and looks goofy. It's an extra 50 bucks to make it a complete kit so I'd get it if I were you
gunner5
September 22nd, 2009 5:08 PM
