tow haul mode, no holdback?
Old Apr 30, 2007 | 10:12 AM
racerx55's Avatar
Default tow haul mode, no holdback?
this tapping sound is more pronounced under my truck, almost sounds likeits from the trans.
When i put it in to haul mode, say i take off and it shift into 2nd gear then i let off the throttle, it will just come down to an idle and i can coast up to 50-60 MPH downhill with no RPM change, it just idles and free coasts downhill. that doesnt seem right to me. it will only hold back normally if i manually shift into whatever gear its in.
it feels like an old transmission with a stuck detent cable.
i have bad luck with whatever i get new or not so i guess im going to take it in today.
Old May 5, 2007 | 4:17 AM
racerx55's Avatar
Default RE: tow haul mode, no holdback?
so has anyone noticed how their truck coasts in gears 1-3 with tow/ haul turned on?
do they allseem to free coast like in neutral or ismine a piece of **** like evrything else new.
Old May 17, 2007 | 8:05 AM
shamdiel's Avatar
Depens on what truck you have. If you have one with the Allison transmission in will automaticall shift down in tow/haul going downhill or if you let off the gas when you have a load on. The 1500 5.3 or 6.0 s that I have driven, without the Allison, act more like you described, when decelerating in tow/haul. That is more like a car would with the coasting you mentioned.
mroakdale
12
Sep 28, 2024 6:06 PM
damone
Apr 29, 2011 7:36 PM
Red Ron
Oct 22, 2008 9:35 AM
steved
Nov 27, 2007 1:27 AM
Clay24
Jan 4, 2007 1:37 AM
