Towing and Power Question
What would cause this? My 95 Z71 1500 runs great normally. When I tow my trailer (about 4-5K pounds) though I have a hard time getting any acceleration. I can put the pedal all the way down and the RPMs don't change and the truck doesn't go any faster than 55-65. The RPMs haven't gone over 2500, so I don't think I am overtaxing the engine. Not enough fuel? The spark plugs and wires probably need to be changed, but everything else is in decent condition as far as I know.
Site Ambassador
Also, with toting that kind of a load, you don't want the trans to be in overdrive. For one, the engine rpm's are way below your optimum power band. And two, you take a chance of overheating the trans.
Thanks for the responses! Yes, I have always towed in 3 and not OD. That brings up another question though: could it have anything to do with the tranny? I had not thought of that.
I haven't checked for any codes. The CEL does not come on...wouldn't it come on if there was a DTC? I can't view fuel trim. It will have to go to the shop at some point. The problem is it pulls fine without the trailer. And I can't bring the loaded trailer to the shop. So how are they going to diagnose this?
About 96K miles. Trailer isn't too old...its a 2007 but it was never used when I got it in 2010. Would I know if brakes were dragging other than taking it apart? Wouldn't there be an odor or noise? Might be good to take it for service to rule that out though. Thanks!
overdrive.. the D with a square around it right? i thaught it was for promoting ease with hills and towing if anything else
Hapy1Luky2
September 23rd, 2011 10:51 PM
Nyron
June 28th, 2010 10:55 AM
REAR VIEW
July 7th, 2007 11:54 PM
ahjah9
December 7th, 2006 10:20 PM
