Notices
Towing w/ 1998 Z71
Old August 6th, 2009, 8:06 AM
  #11
tsduke's Avatar
Originally Posted by bad2006z71
nothing over 200deg for your trans temp for any length of time. 170 is the best temp
also its ok to tow in OD as long as the truck is not hunting for gears.
Is there a difference between hunting for gears and actually shifting?
I'm curious about towing with my 05. Before this I towed with V6's and pretty much in 3rd all the time. Now with the 5.3 I wonder how much I can tow in OD. I have the factor heavy duty trailering package. So far I'm not towing anything real heavy. I will be pulling a 17' lowes fishing boat 500 miles to Canada. Is running in OD gonna be ok? Is a 500 trip in 3rd gear hard on it?
Old August 6th, 2009, 10:01 AM
  #12
bad2006z71's Avatar
excessive shifting or "hunting" is bad. if you drive and either hit a hill or the transmission is continously locking and unlocking the converter, thats not good. if it just downshifts to 3rd while going up a grade and then shifts back into OD, thats ok
Old August 6th, 2009, 10:07 AM
  #13
tsduke's Avatar
Ok, next dumb question.
Can you hear or feel "hunting"?
Old August 6th, 2009, 10:17 AM
  #14
bad2006z71's Avatar
well yes i guess. you will hear the motor reving up when the converter unlocks, then rev lower when the converter relocks. only about a couple of hundred rpm difference when this happens. even more difference if it shifts to 3rd then back to OD, then converter locks, and vice versa.
chevygirl02
February 4th, 2014 4:35 PM
D-Train
March 28th, 2012 7:47 AM
Nyron
June 28th, 2010 10:55 AM
Rhinoguy44
14
May 2nd, 2009 12:31 PM
ahjah9
December 7th, 2006 10:20 PM
Quick Reply: Towing w/ 1998 Z71
