Tranny Problem??
Tranny Problem??
I was driving just 2 days ago and crouz'in at 70km/h and i herd a little "click" and drive just turned into netual? tryed it from a dead start and it still doesnt work? i've checked linkage and it seems to all work? could it be anything else rather than a tranny? because a trannys going to be around 3000 or more. and the truck is worth 4500
Oil in tranny is good.
any help would be awsome
I have Park, Reverse, Netual. The truck has 210,000km or 130000miles. Wouldn't be a joint since i have reverse. i was thinking it may be the little computer that the linkage conects to? but i have done some serching and suposably if that goes in turns on limp mode where 1 and 2 gear work?.
What would cause that to break? Overworking the tranny? It was doing nothing when it broke but before that the truck was used for towing a several heavy loads. for long distances.
towing can be hard on tranny, especially heavier loads over long distances. the fluid could overheat many times and without a trans temp gauge, you'd never really know. two suggestions for you if you fix this rig and keep towing. 1. install a good trans temp gauge. 2. install a good heavy duty trans fluid cooler. the stock one is not really meant to keep fluid cool under heavy load.
