transmission question...
I have a 1997 GMC Sierra Z71 with 350 Vortec motor and auto trans... I also have a 1999 S10 blazer 4x4 with 4.3L Vortec and auto trans. So the question is, are these two transmissions the same? Im scrapping the blazer (bad motor and parted it out) and would like to pull and save the trans if it is. Thanks
They both should be a 4L60e
Best thing to do is get under there and look at the part numbers
Even thought the internals may be the same the wire harness or fluid cooling line hook ups maybe different
Former Sponsor
Even though it will bolt up (assuming they are both 4L60Es) the gearing is likely different.
The stamping numbers would need to be identical to be 100% sure they are geared the same.
I would think a Z71 8cyl is geared different than a V6 Blazer
Coravir
October 26th, 2019 3:28 PM
DSGB
May 29th, 2013 8:54 AM
mushi99999
August 12th, 2007 8:00 PM
